-=Jeff=-
Ken,
I was reading about your journey in the off topic section and wanted to ask about your Speedo problem.
First I was not sure which ECM system you are using.. is it still the Stock one? or did you go to the Speed Density system?
Does the VSS on the trans work? is it even the Stock one? The VSS is wired Directly to the Cluster to display speed. If Chris was scanning the car and was registering speed it is getting to the ECM so we know the signal is good
BUT:
If it is the Stock ECM in the car the VSS wires to the Cluster with is a 4Kppm signal, it is then converted to a 2Kppm signal to go to the Stock ECM. If you swapped to the Speed Density System using an GM ECM, the newer ECM (assuming a 7730 from an Fbody) is setup for the 4Kppm directly. so it could very well be that the wiring is no longer connected to the Cluster for Speed.
Just a thought
BUT:
Just a thought
