boomdriver
The open loop issue is no longer happening. I had a prom from a camaro in the ecm and I switched back to the original.
hmmm
Can't do that. Although the engines are almost the same,. the tuning is lots different.
As far as the throttle plate...vac cannot possibly hold it open unless the spring is missing. If there is nothing thats holding it open, like a bent linkage part or set screw, a build-up of oxidized aluminum can sometimes grow around where the butterfly normally seats. This might keep it cracked open. Get some fine emory cloth and try to polish the bore clean. Be certain to blow out any grit or debris afterwards. If you;re really adventurous, get yourself a dremmel,a sack of buff wheels, some brown tripoli jewelers rouge and about 2 days, and polish the bore of the TB to a mirror finish. That will prevent future corrosion and oxidation AND even aid in performance a hair...maybe a little. Looks nice if nothing else.
You can also polish up the butterfly and bevel the edges of the plate so it can't stick.
For now, clean the crud out of the spring and linkage, clean out the bore, and try it.
