M
Macgyver
Ok Im almost there!!! I got it running much better but its still running rich no matter what. Ive turned the idle mixture screws all the way in and it wont die out. Any change in the idle speed screw and it runs like crap. So my question is what size power valve and jets should I be using on my mainly stock 81. I have the Holley4150 list 3777 sitting on a stock 350 w/ Performer Intake, 14x3 open air element, true duals no cats, soon to be 1 5/8 longheaders to 3in side pipes, and no computer. The person I got the Holley from rejetted it to run on a 400 Pontiac.
In the haynes manual it says that the 71' which came w/ the 4150 was OE w/ #70 pirmaries and #78 secondaries. I dont know what size engine it had though but Im sure it made more than my 190 horsies. I would like jets that would give me some fuel economy though (dont laugh). I forgot to do the finger in the front vent tube test that GerryLP noted to test the power valve but the carb has backfired probably 25times so Im sure its blown. What size can it be changed to to prevent this?
One more problem though the reason why Im real reluctant to take the Holley off again is that the threads in the intake might be stripped now! I was tightening it and suddenly it kinda went limp and just stayed w/ the same amount of tension no matter how much more I tried tightening it. Does that make sense? How much should I tighten these screws, cause I never had a problem when messing w/ the Qjet? Can I put some water sealing thread tape on it to improve that or am I going to have to throw the intake away and get a new one. Im not taking it off to have it machined or anything cause then that would just be a horrible product by edelbrock which has been my experience so far.
This thread was supposed to be a real simple question but I just keep rambling, sorry? Thanks guys.
