holley throttle shaft
baxsom
Cocoa Beach FL
72 454 convertible, 2000 C5 Z51
so i get my square bore intake installed on the 454. i install my holley carb.
it started and runs perfectly but here is the kicker it has vacuum leak. when i spray the the secondary throttle shaft the rpms drop.
i am guessing that the throttle shaft is worn and that is my leak. i just wanted confirmation that a worn shaft would do that.
thanks
i guess i answered my own question. i put some grease on the secondary shaft where it goes into the throttle base and the rpms dropped way down.
looks like a new base plate is in order.
easier than trying to ream and press in bushings
