Re: Re: News!
rjsmith said:
Since the LS6 has two valves per cylinder, and is therefore multi-valve already, it is assumed that your business associate on the GM payroll close to the Corvette developement division means more than two valves per cylinder. If that's the case, it's gotta be an overhead cam engine, since I would hate to see an engine with a single in-block cam (e.g., the LS series) and all those extra pushrods. It would be a neat trick to see someone make that puppy rev "to the upper rpms side" (imagine the increase in reciprocating mass). However, that certainly would qualify as "...a new engine setup".
On the other hand, an overhead cam engine would not be a new engine setup. The LT5 was developed in 1989.
Is it possible that your source works in the mail room at Bowling Green?
He certainly needs to take Design of Internal Combustion Engines 101.
As for "...anything is possible", that may be true, but had you gone to engineering school you would have learned that something may indeed be possible, but have an extremely low probability. It is *possible* I could play center for the Lakers. The probability of that occuring is so extremely small as to be safely ignored.
Is it possible to spend millions to develope new composite materials that would be incorporated into the Corvette chassis to reduce weight? Yes. What is the probability that Chevrolet will do that to satisfy a few buyers who desperately need a power passenger seat? Extremely small.
First....let's put the daggers down and keep the sarcasm in check. "Multi-valve" has a couple different connotations and as far as predicting what it means in terms of the C6, that's how rumors spread which I prefer do not begin from this site.
Second, multi-valve does not necessarily mean an overhead cam configuration and I don't think it's safe to assume so.
Third, the LT5 engine was not developed in 1989. It was actually in the planning stages and began development in 1985 with a Phase 1 Prototype engine brought to life in early 1986.
Last, I disagree with the last assumption:
Is it possible to spend millions to develope new composite materials that would be incorporated into the Corvette chassis to reduce weight? Yes. What is the probability that Chevrolet will do that to satisfy a few buyers who desperately need a power passenger seat? Extremely small. Given past history of Corvette Development, if the technology can be utilized across multiple platforms, starting out on the Corvette and eventually spreading to other car lines, then, yes, it is most definitely possible. A perfect case in point is the LT5 engine. The development costs of that engine was enormous....however, the Northstar engine was born from the LT5 engine and would not be here today if it was not for the LT5 engine. The technology utilized on the LT5 engine trickled over to another platform - Cadillac, and as a result, has proven to be profitable for GM over the long run.
If there is a technology that's costly, that can allow Development engineers to shave 400 lbs off the chassis, all while allowing them to keep luxury items such as power seats, AND that technology can be incorporated into other platforms, GM WILL do this and they've done it before.
Let's try to bring this thread back on track and in focus with what the original question was: is the C5's horsepower measured at the flywheel or the rear wheels.
