Jim Martley
- Joined
- Jan 10, 2003
- Messages
- 48
- Location
- Slingerlands, N.Y.
- Corvette
- 1982 Red ,93 Yellow,93 Brt. Aqua
I am trying to track down a problem for a friend of mine. The car is a 61,000 mile 92 LT1 6 speed convertible. Car starts fine when cold. Run the car for 15-20 minutes and shut it off. 4 out of 5 times the car will just crank over and will not run. Let it sit for 5 to 15 minutes and it will start & run!
I have checked the fuel pressure and it is 37 to 45 lbs and holds steady when shut off.
There is spark from the coil.
There is NO black smoke when it restarts.
I also checked the resistance of the injectors hot & cold. They were 11.2 ohms cold and 12.6 hot. All were within .1 ohm of each other.
I DID find that the injectors were NOT getting a signal when the car wouldn't run.
There is also an intermittant flash of the "SYS" light and "Security" light when the car is running and it will sometimes have the "Service ASR" light come on.
Any ideas?
__________________
Any ideas?
__________________
