yellow77
Well, the air conditioning from Hot Rod Air has now been in for almost a week and I am pleased to announce that the temperature here in Tulsa has started reaching its normal near 100 degrees. The Air conditioning has absolutely no problems cooling the cabin in the vette. I have noticed a slightly higher temperature on the engine temp guage when idling in traffic, but nothing to be worried about. The installation was fairly simple, and if anyone wants, I can post some pics of it. The only problem areas are that when the hood is open, the right front corner of the hood rests on the receiver dryer, so I have to be very careful opening the hood and the passenger side spar of the hood had to be cut to clear the suction line fitting to the compressor. A noticable issue is also one I had with a vintage air product which also uses the Sanden compressor is that at about 3500 rpm and above, there is an audible whine or howl type of sound, but it does not appear to have any effect on the operation of the system.
As a side note to all of this, I also installed an Edelbrock Nitrous Oxide plate system (100 Hp shot), and can post pics of that too, if anyone would be interested.
Cheers All
Richard
Cheers All
Richard
