W
wolf_walker
Alright, next round of twenty questions..
Put a nice new high flow RobertShaw T-stat in the vette today, 180 degree unit. Hit the interstate this afternoon running about 70mph, was about 90 degrees out.
Man, not plesant. I've never been in such a hot miserable to drive vehicle in my life. And I can stand a LOT from an old car I like. I think I lost about five pounds in that darn thing!
It's like an oven inside, even with both windows down, the floorboards and center console are almost too hot to touch from heat radiating up. So, what's good stuff to insulate the crap out of that car when I replace the ragged carpet?
Second hot problem, which goes along with the t-stat replacement. This thing (74, stock) is showeing 200 degrees on the highway, +/- 10 degrees. Is that normal? I've never actually owned a small block chevy with a real temp guage, but that's warmer than I like any of my other old V8's. I'd almost bet money if you hit the mountains it would overheat the first long grade you pulled in second gear. I tried the 180 t-stat, but it made very little if any difference. The last fellow that worked on it any amount also left word to never run more than the 9lb cap that's on it, which is wrong, it's suposed to be 16lbs. It has never activly overheated since I've had my hands on it, but I'm told it used to on long trips.
So now's the part where you tell me the radiator is cloged up.
Replace or re-core? Who has a decent one cheap?
Thanks folks...
Thanks folks...
