Hotchkis Sway Bars
Mean In Green
Burlington, MA
1998 Fairway Green Metallic/Light Oak A4 Coupe
Matt G. at Exit 28 Motorsports said they no longer carry Hotchkis swaybars or Bilstein Shocks, so I went ahead and ordered them through LAPD... I decided on this combo based on many posts I read at C5Forum.com on the subject. It seemed that most people felt that was the way to go. Then, Matt G. writes me back and says he doesn't recommend the Hotchkis because of noise problems and to go with the Z06 swaybars instead. I've already put in the order, so I'm a little concerned. Has anyone had noise problems with their Hothckis swaybars? Are they NOT, in fact, my best option?
Thanks,
Mean In Green
98 A4 Coupe
c4c5specialist
Technical Advisor
New Haven, Ct. USA
Nope, but someday.
Correct, to an extent
Hi there,
Matt is correct, to an extent. The noise, is really caused, for the most part, by the end links. The bars themselves really do not make noise, if installed correctly.
Personally, I like 02 ZO6 bars myself, but this is a personal preference, NOT anything else.
Progression of predictability when at high speeds in the turns, are what I like best about FE4 sway bars.
I hope that this helps, besttoyou, c4c5:hb
hcolon
miami fl
1999 c5 coupe
Question, is there a difference between the Z-06 sway bars and the Z-51 sway bars, and if so what?
Herbie
