How do you replace spark plugs + plug wires
  • Thread starter Thread starter boonie
B
boonie
i am replaceing both spark plugs+ spark plug wires on my 94 C4 AUTO, how do I do this? what steps do i take to remove spark plugs#7,#8 which i understand are the most diffcult to reach? must i buy some special tools?
thanks boonie
If you haven't done this before I suggest you take it to a good mechanic to have it done. It is easy to mess something up if you don't know what you're doing.
No special tools required. From what I can remember, I did use a universal and some assorted extensions. You do have to remove or loosen some things to gain more access. This is easy, look it over and you can see what has to be loosened and pushed gently aside. This will give you access. Patience and use the right combination of tools. The wires from what I can remember are easier on the passenger side. The drivers side is another story.
