Question: How is rear license frame removed to replace plate?
malundquist
New member
Bothell, WA
1999 Corvette Convertible - Torche Red- 6speed
Should be easy. How do you remove the frame surrounding the rear license plate in order to replace the plate? Does it pop-out or are there screws holding it on that need to be accessed from the trunk. It is a 1999 convertible. Thanks. Mark
Did you get your answer?
I'd like to replace mine also, but the frames I've found don't look as good. The stock black frame is wider which covers the area , next to the reverse lights. Did you change yours out? Find a good replacement?
There are push tabs (4) around the perimeter that allow the frame to pop out. No screws...
Here's what I found that worked
Sent from my SM-T530NU using Tapatalk
