sxyvet
- Joined
- Aug 3, 2005
- Messages
- 248
- Location
- Dandenong,victoria-Australia
- Corvette
- 1991 ZO7 coupe, 6 speed,red on red w/most options!
hi there guys!
how are you all!
just wandering please roughly how much extra horse power i can get up to for my 1991 l98 corvette if i install these corvette hp parts!
i was hoping for 300 horsepwer instead of the standard 260 hp!
here is the list
throttle body air foil/done
k&n air filter with open air box/done
pollution pump pulley ellimanator kit/done
throttle body bye pass coolent mod/done
mat sensor relocate kit
performance switch
hp spark plug leads
bosh plantium spark plugs
high preasure fuel regulator
magnaflow rear free flow mufflers with lt 1 tips and mandrel bent stainlesss exhausts with with i single high flow cat/done
hi performance pulley kit
hyper tech power coil /cap kit
hei control module
adjustable throttle position sensor
power coupler/ intake hose straight design with out crinkles/ribbed.
power aid throttle body spacer
also have tried 160 degree thermostat, does this really help with performace?
are these mods a good start?
i am on a bit of a budget so i thought this would be ok!
was told that bye bye corvette central that bye removing vaccum hose of fuel regulator and manifold on other end that you can gain 5 lb of fuel preasure which i tried with my fuel preasure guage and it boosted it up to 45 lb!
what i did was add a mower fuel small filter on each end so that it doesnt suck up dirt or any thing!
is this safe to do like this?
does bye disconnecting it really work?
any other mods/tips info would be really appreciated very much!
thanks heaps
glen
sxyvet-australia
sxy_corvette@hotmail.com
how are you all!
here is the list
performance switch
hp spark plug leads
hei control module
thanks heaps
glen
sxyvet-australia
