How much refrigerant oil???
Booie
Cheektowaga, New York, United
1979 Dark Green L-48 Coupe
Anybody know how much refrigerant oil goes in my 79 AC system a line broke and oil went all over.now I need to refill and recharge system.
If you have already converted to R134A refrigerant, they have a mix of freon and oil in a can that you can use for your first refill. After that use the straight R134A to fill to the proper charge.
If you haven't converted from R12, you will have to replace it with Freeze12 or another substitute.
The system uses about 7 Oz of oil per total charge.
No I didn't convert and I was going to have the R-12 put back in Iwas told it is a lot colder than R134A. But didn't know how much oil it takes. Just 1 oz. Total or 1oz. per pound of R-12
Bruce
I would not add more tha a couple of ounces. If there is to much oil than there is not enough room for freon and the system will not work properly.You probably did not lose as much as you think but with the age and failure 2 ounces should be plenty just my 2 cents Steve
