OldCorvetteFan
- Joined
- Jul 3, 2005
- Messages
- 117
- Location
- Northwest Illinois
- Corvette
- Black 95 6 spd Coupe (Sold); 2011 GS
The rubber coating on my '95's console is showing significant wear, and I also have a new leather boot, knob, and insert.
I've been reading tales of the difficulty of removing the lockpin, and I'd been putting off this project for some time. Well, I had some time this afternoon, and thought I'd at least see if I could get the knob off.
Here's the current shifter knob ...
Step One is to remove the shift pattern insert, which I did by first putting a small flat blade between the top of the insert and the knob.
After loosening it a bit, I then moved the blade to the bottom, and it easily popped out.
Step Two is the removal of the pin that locks the shift knob on the threaded end of the shifter shaft. I had read a variety of ways to remove this, ranging from "I used a set of needle nose, and it came right out" to "I took out the top, locked vise grips on it, and pulled until the pin came out and I hit myself in the testicles with it". I tried the vise grips first, and got nowhere. I'd read where someone recommended a drum brake adjuster tool, and then it occurred to me that I could probably use a mini-pry bar.
Here is the pin after the insert is removed ...
I tried the pry bar on three sides - the first was the top, and I discovered that there wasn't anything to hold. I then tried the pasenger side, and thought I felt the pin move up a bit.
I then put the pry bar on the left side, and the pin slid right out. This pictures also shows how much my leather boot has deteriorated - see the holes? I get a good bit of heat through that as well.
Here are the old knob, insert, and pin on the bench.
This picture shows the detail of how the mini-pry bar and the pin interact with each other.
And this shows how the pin orients in the knob.
All in all, it was pretty straightforward, and went a lot easier than I'd expected - especially after I'd tried it with the vise grips, and wasn't getting anywhere!
Steven
![Step_00.jpg](http://i101.photobucket.com/albums/m75/OldCorvetteFan/Shifter_Knob_Removal/Step_00.jpg)
![Step_01.jpg](http://i101.photobucket.com/albums/m75/OldCorvetteFan/Shifter_Knob_Removal/Step_01.jpg)
![Step_02.jpg](http://i101.photobucket.com/albums/m75/OldCorvetteFan/Shifter_Knob_Removal/Step_02.jpg)
![Step_03.jpg](http://i101.photobucket.com/albums/m75/OldCorvetteFan/Shifter_Knob_Removal/Step_03.jpg)
![Step_04.jpg](http://i101.photobucket.com/albums/m75/OldCorvetteFan/Shifter_Knob_Removal/Step_04.jpg)
![Step_05.jpg](http://i101.photobucket.com/albums/m75/OldCorvetteFan/Shifter_Knob_Removal/Step_05.jpg)
![Step_06.jpg](http://i101.photobucket.com/albums/m75/OldCorvetteFan/Shifter_Knob_Removal/Step_06.jpg)
![Step_07.jpg](http://i101.photobucket.com/albums/m75/OldCorvetteFan/Shifter_Knob_Removal/Step_07.jpg)
![Step_08.jpg](http://i101.photobucket.com/albums/m75/OldCorvetteFan/Shifter_Knob_Removal/Step_08.jpg)
Steven
