 That is most definately a good thread.Patrick said:Cuvette,
A rapidly flashing turn signal typically means you have a burned out turn signal bulb. Check out THIS THREAD.
-Patrick
   ) but the other method as indicated in the thread.  Jack the car, turn the wheel as far as you can, then remove the small panel behind the air-dam and reach up into the opening.
MM-C5 said:If you try to go down under the headlamp, make sure you have it locked open and the wire disconnected. It woud be a major bummer to get your arm caught!
