mason1968
Hi,
I have a small block Chevy with one cylinder (#6) that seems to be running lean.
The engine is a 350 with a B&M 144 supercharger and is carbureted. I recently installed a set of headers with ceramic coating. The coating on the primary pipe for cylinder #6 has burned away.
What can cause one cylinder only to be lean?
I have a new MSD ignition system installed. I think it might be a leak in manifold to cylinder head gasket or I might have a problem with my values in that one cylinder.
Any info would be helpful.
Matt
Matt
