Whitehorse
Update: The howling has been fixed with $9.95 worth of posi additive. It hasn't peeped, chirped, squealed, or howled since I put in the additive. Now the only thing howling are the posters at the end of this thread.
Thanks for all the help folks.
Original post:
I have a 95 with 43,300 miles on it. It started howling when I went around corners about 2 years ago. It is only noticible when the temperature outside is between 75F to 85F. Sometimes I'll hear it a little outside that temperature range but between 75F and 85F it's really loud. It only seems to do it with I'm turning a sharp corner. I never hear it while going straight and never when I turn the steering wheel if I'm not moving. I never hear it on the highway.
For the past couple years I thought it was in the front but today with the daughter in the car and the windows rolled down, her and I agreed that it was coming from the rear. It appears to be getting progressively worse. I thought it might be the rear end oil and I just had that changed for the first time. The mechanic told me the oil should be changed every 7500 miles on this vehicle. Is that correct? I've never heard of a vehicle needing the rear end fluid changed that often. I always thought it was 50,000 miles.
I just looked in my manual and it looks like it might be the side and pinion gear in the rear end. If so, where should I take my car in Wichita, Kansas and how much should I expect to be paying?
Thanks in advance.
Original post:
Thanks in advance.
