HP
jojo1
New member
owosso,michigan
1996 white coupe
Hi ,everybody,
I own a 96 corvette and looking for ways to add serious horsepower to my vette. I have read all about the rip-off things you can buy and I am staying away. All you 92-96 LT-1 owners I can sure use your help. It will be greatly appericated.
Thanks again,
joj1
S
speedmaster4
simplest way to add power is to spray it (nitrous)...altho nitrous is a pita due to constant reloading of the bottle (typ 30 sec use per fill)...increasing engine displacement is better, but removing the engine and big mods/replacement obviously reqd.
simplest big performance add is to change the rear axle ratio (gears)...the factory was hindered by CAFE requirements and the corporate edict of ''no gas-guzzler tax vehicles'', and the small increases in fuel economy which the lower rear gear ratio gave were important to GM...but you can switch to a more ''performance'' oriented rear axle ratio and find substantial improvement, and in ''real'' life conditions find very little change in fuel consumption.
Notorious
Confederate States of America
Highly modified '95 A4 coupe
Build an engine. It's very realistic to expect a well put together stroked LT1 to make 375-400 RWHP and still be very driveable and reliable. And it will still get very good mileage if built with overall efficiency in mind.
Hrtbeat1
MS Gulf Coast
'90 coupe (gone) '96 CE LT4 Z51
I agree with Speedmaster a gear change is going to give you a great feel for the HP you already have. Other than that I would sugest a cam. You really need to figure out what you want to do with the car first.
:w
:pat
