youwish2bme
After completely rebuilding my rearend/suspension I have had a vibration at 75mph and above... Well after checking the driveshaft,halfshafts,alignment,balancin g the tires,I think I found it.. It required once again removing the differential to see that one of the yokes is not made correctly. I just wanted to provide this information to others so that you don't have to go thru the hassle of the installation of your rearend only to have to remove it again.. I used the HD cap style yokes for my differential b/c as those that know me.. I like to get on my vette...
Here is the passenger side yoke this one looks good..
Here is the drivers side yoke and the left measured from the yoke to the dust cap is about 18.5 mm the right side is 9.5 mm from the yoke to the dust cap...
Jeff thanks for giving me those calipers b/c mine would not have been able to measure this with out them..
Bill I'm glad we finally found it, I guess I'll be off the road for a couple of days and miss the Waterside event but hey this was too important not to fix.... So if anyone was going to Waterside and didn't register there is now an open spot....
I have already talked to the vendor and they are going to replace it so no need to ask whom it is. Just if you are rebuilding your diff with those HD yokes check them to make sure that they are true...
Dave...
Dave...
