- Moderator
- #1
vetteboy86
When you C4 guys strip the wheels and do the restoration process, did you all remove the tires from the rims? If not how did you protect the tires from the stripper?
Craig
Craig
vetteboy86 said:When you C4 guys strip the wheels and do the restoration process, did you all remove the tires from the rims? If not how did you protect the tires from the stripper?
Craig
nyernga said:When I did mine 3 years ago or so, I kept the tires on the wheel. I used acetone to strip the clearcoat as the "professionsl strength" stripper was a joke. It's alot of elbow grease but well worth the effort.
Len![]()
Vettefan87 said:Mad-Mic recommended just using the like stripper in a can stuff, is that what you used and it didn't work. I just picked up some rims the style as yours and might start polishing them for an excuse to buy new tires.
nyernga said:I tried Buschs's Clear Coat remover. Got it from ecklers. It's gel like to stay in place but it did nothing to remove the clear. The acetone along with paper towels, a stiff brush and alot of rags and I was done in an afternoon.
Len![]()
I thought that strippers came in giant cakes!Vettefan87 said:Mad-Mic recommended just using the like stripper in a can stuff, is that what you used and it didn't work. I just picked up some rims the style as yours and might start polishing them for an excuse to buy new tires.
