- Moderator
- #1
vetteboy86
I hooked the software up to the car tonight, and I could monitor various charateristics. I was really intrested in the O2 voltage. I noticed it didn't move very much, I thought it would go low, then high over and over if the car was running right. I hooked my brothers car up, and it did move low to high. I then discovered a variable called fuel mixture status. I noticed his went rich lean rich lean, and did that over and over. I know this is normal. I looked at the graph, and it looked like a PWM waveform, very normal.
I hooked mine back up and found this variable, and all I see is lean all the time. I watched the computer while my brother adjusted the fuel pressure. We turned that thing every which way, and the lean condition did not go away. In about 15 minutes of run time, it was rich maybe 10 seconds, and that is probably too much. There was about a 5 second period when it went back and forth.
Here is the question, what is causing this. I can adjust the fuel pressure up and down, although the needle isn't very steady.
Any suggestions???
Any suggestions???
