KLUTZ
- Joined
- Nov 9, 2011
- Messages
- 20
- Location
- Alcona, Ontario, Canada
- Corvette
- 1987 Bright Red convertible
What is this Z31 on my '87's build sheet? Is that the stock suspension ID#? I can't find it listed anywhere.
'87 had Z51 "Perf handling" option ( I own one ) just like other years
and was the 1st year the softer Z52 "sports handling" pkg was available
1596 RPO Z51 produced in '87
12662 RPO Z52 produced
Interesting...
I was told by someone in Kentucky that the '51 was replaced by the '52 for a yr or two but was basically the same thing with a softer /slower spring rate. All that was needed to be the full on Z51 was the hardest spring that you could tolerate....which I did install, regretably...
Mine is labeled Z52, but has the fast rack, big solid sway bars, 'steins and everything else. Now it has a 499 lb/in spring that easily qualifies it as Z51.....(buckboard)
I miss my old 230 lb spring.....:duh
I had never heard that the "Z" code also covered trim packages....I always assumed it was strictly suspension package code.
So, what can I expect the ride to be like with mine when I get it roadworthy? Soft, hard, bumpy, rearend sway?
