Tripleblack51
I removed the carb on my '67 to replace the gasket between it and the manifold. (small gas leak)
While the carb was off, I decided to do a little cleanning.
I got the old de-greaser out and sprayed the manifold, used a wire brush and just wiped it off. It looks great!
Now for the boo-boo.
I noticed that the clamp that holds the hose from the radiator to the expansion tank was a little rusted.
So I decided to replace it. I loosened it and jiggled the hose gently (I thought) to pull it free.
Two thirds of the nipple that it attaches to broke off in the hose.
I re-attached the hose to the remaining part with a brand new shiney clamp.
Will this be enough to hold it?
Is there a fix for this other than a brand new radiator? It currently has a Harris aluminum.
It turns out that the new carb gasket is an incorrect one and I didn't have the time to drive out to the next closest store so I haven't been able to start the car.
Your feedback is appreciated.
Thanks,
Pedro
Thanks,
Pedro
