Also, when you finaly do go to look at a car, you might want to check the onboard diagnostics to see if any error codes are set in the car.
The "diagnostic display" mode is entered with the following procedure: 1) turn on the ignition but don't start the engine. 2) press the "reset" button to turn off any warning messages 2) press and hold "options" and 4) while holding "options", press "fuel" four times within a 10-second period.
If there are any errors they will display a code (four digit number followed by either H or C...H= history = problem happened in the past but is not currently a problem C = Current = thats a problem now) which you can look up in a bunch of places on the net (including here) and in the car's owners manual if present.
One of the worst things about a C5 is that it has eleven computers in it that have to talk to each other, but then again, one of the best things about the C5 is that they pretty much do it so well ;-) and they make driving one almost effortless. (I mean if you can't drive a C5 fast, you should probably think about not driving fast at all
I love my car. The only thing I would like that I didnt get is the Selective Ride Control, and the fact that I bought it with 43k miles. If I had it to do over again, I'd wait till I found one with less miles (I just can't stop driving it
Good Luck, and stop back and let us know what you get when you get it.
