I need MORE 4L80E info!
grumpyvette
Loxahatchee, FL, Palm Beach co
ok all you transmission guys, IM also VERY interested in the answers because I purchased a 4L80E to install in my 1985 corvette when I do the swap to the big block engine , because theres no 700r4 thats going to handle the torque numbers that engine will produce, so any info will be greatly appreciated, on how to find cheap ECU/TRANS controllers OR how to modify the 4L80E trans to full manual control. hopefully theres some knowledgeable trans guys on THIS SITE that can help!!?? converters available ? lock up/non-lock-up? performance shift kits? ETC. IM SURE MOST GUYS CAN USE GOOD INFO! heres all the links Ive found......... NO! NOT ALL THOSE QUESTIONS ARE FULLY ANSWERED IN THE LINKS
does anyone have the part number for that manual converion KIT,? or other usefull info?, instructions on the conversion? programing and installation info on the electronic controllers?, part numbers and prices? other options?
does anyone know where a diagram for the connections can be found?
differances between the differant year 4L80E transmissions?
how do the 4L80E trans differ from year to year?
what are the part numbers for the TRANS CONTROLLERS
WHAT STALL SPEED CONVERTERS ARE AVAILABLE and with lock-up?
which are the best built?
what cross members fit?
what drive shaft yoke? part #?
HERES SOME INFO ON THE 4L80E
http://www.atg-autotrans.com/4l80hous.htm
http://www.transmissioncenter.net/4L80E.htm
http://www.transtec.com/specific_trans/4l80e.htm
http://store.yahoo.com/hardparts/4l80e.html
http://www.drivetrain.com/4l80e.html
http://www.fbperformance.com/transmissions/gm4l80e.html
http://www.sallee-chevrolet.com/Transmission_Control_Modules/4L60E_4L80E.html
http://www.compushift.com/
GM PART # 24200161 (wire harness)
http://www.tciauto.com/tech_info/trans_dims_tables.htm#4L80E
http://www.gm.com/automotive/gmpowertrain/transmissions/hydra/apps/4l80.htm
this might help
PLEASE HELP OUT ,ANY USEFULL INFO IS WARMLY ,and GREATFULLY RECIEVED
THIS IS INTERESTING
http://www.kdsperformance.com/tranhigpersh5.html
The ultimate high performance shift kit!!
Includes detailed instructional video.
Engineered for the 'perfect shift' - firm muscle car shifts.
FULL manual shifting.
Perfect for heavy duty/towing applications.
Stops direct clutch burnup.
Prevents hi-pressure damage.
Holds shifts and downshifts to any RPM.
Contains detailed instruction booklet.
Can be installed with transmission in vehicle.
Requires no specialized tools.
100% Made In USA!
Engineered/Designed by Gil Younger - the father of the shift kit.
TR10101 $179.95
thanks for the info
btw
THIS IS INTERESTING
100% Made In USA!
TR10101 $179.95
Im leaning towards the $180 manual shift kit as IM TOTALLY sure that a $1000 -$1200 trans controller is WAY -way-totally, criminally, overpriced, especially when I can buy a whole desk top computer with hundreds of times larger capacity for that price, and having been in the electronics buissiness I seriously doubt it cost $70 to manufacture
a manual shift kit will be fine and in an odd way seems like converting to a manual 4 speed like a muncie but without the problem of missed shifts,or pushing a clutch and the clutch linkage install problems or the reballancing of the engine caused by swapping from a flexplate to a flywheel
there APPEARS to be TWO versions, I called TRANSGO, they said NO COMPUTER NEEDED ON THE FULL MANUAL SHIFT KIT
full manual
http://www.bulkpart.com/cgi-bin/miva?Merchant2/merchant.mv+Screen=PROD&Product_Code=98365&Category_Code=4L80Esk
reprogramable
todays modern advertising you can never be too sure but this is lifted from the Performance Automotive and Transmission Center website: http://www.transmissioncenter.net/4L80E.htm
Quote:
The baddest of the bad, this is a non-electronic 4L80E transmission. Some of the features are: Full manual shifts - the transmission will be in the gear you select and changes to any gear you choose when you move the selector, no computer or wiring needed...
That sure is..
My brother works for ATIperformance, I'll give him a call and see if he will ask any of the rebuilders if they know of any other leads.
