9
91callaway
took tt out after 6weeks of non use. drove around for 1/2 hr. later under slow accelleration to 4,000 rpm in fourth gear i heard a muffled poof, pop like sound. all gages read fine and i took foot off the gas. since then everytime i take foot off of the gas i hear a slighter poof, poping sound. sounds almost like a very soft series of backfire's. callaway said one reason could be a loose clamp from intercoolers to turbos. brought car to local garage and all three were tight. they did notice a little blackening (small exhaust leak) at rear of one cataletic converter where it connects to rear exhaust. the sound seems to be centrally located, but hard to tell. callaway said not to go into boost because may hurt turbo, not knowing the problem. i have a sevice appointment with callaway and they appear to suggest not to drive the 50 miles. car starts fine, all guages normal. going into boost is one way to find out for sure but do not want to make a small problem, if turbo related, a big one. adivce????
