S
sscam69
I acutally didn't strip the threads they were in bad shape but I put the finishing touches on it.
Its an aluminum manifold and as I was bolting down the carb the threads gave way. My mechanic suggested that I get studs, which I did and as I was torueing them down one of them gave way. Out of the 4 two are good 1 is almost gone but can hold and well the last one gave way. It was a used manifold and that was the way I bought it.
Where can I buy a thread kit to fix it. I have seen in Chevy Hi-Performance kits available where you drill a bigger hole, thread it and put a steel spring like thing in place that has the same inner diameter of the original screw so that you can reuse it.
sscam69
sscam69
