zackh
New member
I just joined the forum,and hate to start out asking questions, but I have a problem, and don't know how to resolve it.
I posted in the tech section, but no one replied.
I have a 2004 c5 with auto trans, and am replacing a broken shift cable.
It is all in place,connected to the brackets, but the cable end that attaches to the trans lever is about an inch,maybe an inch and a half from meeting up with the shift lever on the trans.
Both trans, and shifter are in neutral position.
I tried to adjust at the cable end adjuster, and still the end doesn't line up with the lever on the trans.
I removed the cable, and set it next to the old cable,and they are exactly the same, so I am pretty sure I got the right cable when I bought it.
I just can't figure out why the cable end doesn't line up with the trans lever.
I sure would appreciate any help you can offer.
Thanks in advance.
Thanks in advance.
