Paranoid
The starter fired right up, good cranking power. Then we (my daughters & I) caught our first leak. A bad AN fitting feeding to the carb line. It was sprouting like a water fountain. Tightened it up, still leaking. Looked around and made a new line from the pump to the carb double feed line. Start her up? Still got a small leak from the new fittings. Tightened them up and got a couple water leaks from the temp sensors. Also had a small oil leak from the fittings. No problem just needed tightened.
End Result? I have the evil back-fire thru the carb syndrome. That's what I feared most. I really think one of my mechanical weak spots is anything related to the distributor and timing. So help me out here guys.
I guess it's a timing issue, but I was very sure I had everything dead on. When I started it, it ran for about 10-15sec and then BOOM! Scared the crap outa my kids. I repeated the start about 3 more times with the same result. One of those times I had it running for about 30 seconds before the boom, but I slowly took the idle speed up. I couldn't believe the tach, I was slowly giving it gas but the tach was moving very slowly, then Boom. I wanted to get the RPM's up because I knew a new engine shouldn't run at idle at the first start up.
Prior to this I instructed my daughter that if she saw a roaring flame thru the carb to hit it with some water. Well it was no roaring flame but she doused the carb with the hose anyway. :eek
I'll tell you though, it was a great relief, after 2 and 1/2 years, to hear that monster speak. It sounded loud and angry. Like I woke it up from a long rest.
I guess it's good news that I got cranking going, I have spark and combustion. The worst could have happened, but didn't, that being when I turn the key I get just a click. :cry
So steer me in the right direction here .....what do I checkout first?
Len
I like C1-C2 better that's why I'm posting here.
Len
