Hi there,
Honestly, if you have not had the car check in a year, 90% certain that you need a calibration update.
I recommend that 94 and newer Corvette owners check at least once a year for updates to the programs in the PCM. Program updates occur for many reasons. Fuel formulations, EPA, refinements in optimal operation of the engine, transmission and other things are all part of programming updates.
It takes about an hour to correctly program c5, as there is a special tool needed to isolate the PCM when programming. If it is NOT done correctly, there could be massive problems afterwards.
No, the PCM will never revert to another program, as it is rewritten over the old one when it is installed.
Another thing you must consider is mods on your car, do you have any which would change optimal air flow into your engine????
Other than that, the dealership can print out the calibration number that you have now, and the one that they will download to the car.
Allthebest, c4c5
