Lib
74 big block 454 with stock Quadrajet.  Can someone tell me the function of the idle stop solenoid mounted on the throttle side front corner of the carb? Also, how to correctly test the solenoid for functionality?
I thought the solenoid is there to raise the idle rpm a little when the A/C pump is on, otherwise the idle rpm will be on the edge of to low and shut down. But I could be wrong?
Greetings Peter
Greetings Peter
Greetings Peter
