C
Charlie '64
Good news is, I found the problem, bad news is ......! I started a thread a while back about a brake light not working on one side at the rear, and thanks to you guys, traced the problem to the turn signal switch. Took the steering column apart and found two of the "tangs" at the top of the mast jacket had broken off allowing the retainer to move around inside the mast jacket and rub on the wire harness that attaches to the turn signal and cut the insulation on most of the wires. OK, so now I'm getting ready to order parts to rebuild the steering column. I'm going to try and clean up the turn signal bell housing and steering wheel hub and paint them. Does anyone know what color ie "shade" of black these two pieces were originally and where would I find the correct paint. My car is not an NCRS, but my plan has always been, when I have to do anything to the car to try and keep it or restore it to as correct as budget will allow. I guess while I'm asking, do you guys have any recomendations for a parts supplier. I have used Corvette Central lately after having used Eclers in the past. I've got a fair list of parts needed to rebuild the column and thought maybe someone here may know a more "reasonable" place to order from. Thanks again for all the help, this forum is sure a great place for us newbies to get help and I appreciate you guys that have been doing this for a while sharing your experience. Thanks!!
