withoutremorse42
Found a similar thread weeks ago but can't track it down anymore.
Question 1.
A few days ago, my alternator wasn't charging. Replaced it, checked the battery, checked the groun and lead. Turned out the culprit was the brown (ign power) wire in the 2-wire clip going into the alternator. Not having great electrical fixin skills, I simply ran a new wire to the IGN slot in the fise box. Now the ALT works and charges, but when I turn off the key, the engine runs (though at a lower voltage reading) until I pull that wire from the IGN slot in the fuse box. Ideas?
Question 2.
After days of running the battery down while troubleshooting then putting it on the charger at night, it's acting a bit funny. After the first couple days of troubleshooting I had it bench tested and all was good, battery is still somewhat new and in good shape. After another day or two of the same abuse, the first couple times I turn the key it will barely turn at all, seeming to be a very dead battery. It may do this 3-4 times, then kick to life and crank plenty hard, just like normal. Reads 14.5 volts or so when running, around 12.5-12.7 when sitting.
Question 1.
Question 2.
