J
jfmenden@aol.com
I have an 84, the RPM side of the dash cluster flashes, and the radio has ignition static. I have had it in the dealer 3 times, they charged me 500 to rebuild the dash cluster, did not fix, then said it was normal when cold, then said there was a short on the engine ground, still did not fix. I am pulling my hair out here. Have new wires, plugs, cap and rotor. I am pretty sure it is an ignition problem as it is only on the RPM side, and in the radio. Also, when I hit the brakes, has a loud popping sound through the radio coming from one of the brake switches. Any ideas what to check? Is there a noise suppression device on the car? Or some other ground spot I should check? Hate to spend more money taking it to the local corvette shop. Any help would be appreciated.
One more thing, the left side hood light blinks when running. Something is definitely going on with the ground circuit I think.
Does anyone know if the Tach Filter could have anything to do with it? Also, the wire that comes out of the distributor and goes to the tach filter before going to the tach has an extra wire hanging out? Is this for an external Tach or should something be attached. I can't find anything in the schematics
find it!
