boomdriver
Has anyone had to take the ignition switch out ? (87 c-4 coupe, auto, tilt, telescopic column)
The FSM is a little vague on the procedure and was hoping for some tips and guidance on the process.
I'm having an intermittent problem with the starter....turn the key and nothing happens. Then the next attempt will be ok. Everything points to the ign switch on the column being out of adjustment or simply worn out so I figure I'll just replace the thing and clean up inside there and look for other worn items under the horn button. To be clear, I'm NOT talking about the KEY switch....tumblers and lock mechanism. I am referring to the actual electrical switch that does the work of making contact so that power gets TO the starter and accessories as key position dictates. I have done other vehicles before, but never a tilt/telescopic wheel with a VATS type key. Is this something that CAN be done at home or is it such a PITA that its worth paying a shop a small fortune in labor to change out a $20 switch?
Any suggestions, advice or tips would be appreciated.
Lee
Lee
