I
Inspector Lou
My 90 has no acc. position. The key will turn backwards but nothing lights up. I am assuming this is the ign. switch but don't know where to find it so I can check it. Can my loose steering column be the cause of this like it is to my highbeam switch. I am planning on going into the column this weekend to fix the loose bolts/pins and want to know if I should do the switch while I am there or if it is farther down the column and can be done at a later date or maybe I'm lucky and tightening up the column will fix my ign., highbeams, and loose wheel all at the same time? Wouldn't that be something...
