norvalwilhelm
Last night I took my Brodix 2X heads apart to start work on them.
The intakes are 340cc and I found the intake ports close to a match, not right on but close, within 1/8th of an inch. It will take little work to match them to the intake.
The exhausts are really small in comparison. I will keep a lower flat on the port but the sides and top will be opened up a lot. The lower flat will be straighten out and moved slightly lower.
I did find the pockets under the valves crude. They would machine for the seats and any lip was left hanging in the port
The combustion chambers were also quit rough and will take work to smooth them out.
I don’t like the fact that the exhaust had no valve seal on them. I will have to look into that. As for the 800 pound open valve springs, they will have to go and a new set closer matched to the cam will replace them.
O well the company has a good reputation for casting quality. I will just have to make the finish better. Gives me something to do for the month of December.
