Hrtbeat1
Well guys things don't look so good. I pulled all the carpet and jute padding out of the interior as a start to my stereo install. When I got the seats out and the front carpet out I noticed that the floor pan under both seats was bent up in the corners near the seat belt assy. Not only that but the front of the floorboard on either outer forward corner is cracked. The drivers side isn't real bad but the passenger side took a pretty good shot.
I got to looking at the underside and could see where someone had placed a jack too far under the car and jacked it up. Nice circular dent on the rear part of each floor pan. I spent about two hours last night with body hammers and drifts straightening out the floor pans. I had almost forgot that I had these body tools its been so long since they have been used. I have to admit after I got done last night it looks pretty good. Not too bad for a shadetree body man. From the underside you can barely tell that it was bent.
The question is how should I go about repairing the front section ... this is fiberglass. I've got some ideas, but would like to know what you guys think. The passenger side has a crack that runs about 10 inches fore and aft (about half of it goes up the slope of the floorboard right along the moulded curve) a hole about the size of a quarter, and another crack that goes left to right about 3 inches. I had noticed this before but looking from the underside all I could see was black. Turns out it was the black rubber on the underside of the carpet. Of course the jute padding was soaked ... what a mess, not to mention stink.
In the rear section I started laying down some "Frost King" duct insulation. This was primarily for a heat barrier but I've seen threads that this stuff really works well as a sound barrier also. I have planned on laying out the whole interior with this stuff, another reason for pulling the carpet, ect out.
I will try and post some pics when I get home.
