Vette/Berlina-coupe
- Joined
- Nov 18, 2002
- Messages
- 284
- Location
- southern california
- Corvette
- C3-coupe/MercedesBenz-540K replica! Racing-SB-V8!
---Need for improved Hand-brake....
FYI: ~There is a critical need for an aftermarket improved mechanical C3/Hand-brake (GM referred to it as a 'Parking-brake, because it is frighteningly useless above 3 to 5 mph)!! The lack of effectveness problem resides in the absurdly small/drum-brake with expanding shoes, which necessarily resides concentrically with the rear/Disk-brake Rotors (-which are themselves quite adequate. --once one converts the hydraulic-cyls. to 'O'-ring seals, -instead of the original flange-seals, which can pump air into the hydraulic-system, resulting in catastrophic brake-failure!). As an automotive/Design-engineer i initially contemplated ventilating the drums with a myriad plurality of 3/16"Diam. radial-holes, as was done quite successfully some years ago when all that was available for racing was drum-brakes! However, i am now proposing the somewhat more effective CNC-machining of about 40?/cross-slottings (ie: 1/4"-Wide x 1/16"-Deep transverse-grooves) spaced circumferentially about 3/8"-apart; --thereby serving to increase the gripping-friction approximately 600%(6x) for a significantly improved E-brake(emergency) action, -and likewise greatly improved gripping-friction when parked upon an inclined road such as a steep driveway (-which is presently impossible with the OEM drum configuration). There would be no need for alteration to the Brake-rotor portion, -nor the driver's Hand-lever mechanism whatsoever. Accordingly, i'd like to hear from anyone interested in implementing this up-grading to their C3-Corvette, --perhaps the next time they embark upon a rear-brake overhaul. The ideal senario would be to have a pair of such modified Drum-rotors made-up by a Machine-shop, -so as to have no down-time; -just slap-on the new "Cleated/Drum-rotors TM", --and enjoy significantly safer motoring as a result; --don't leave home without'em!!
~Robair VonHeck (E: robair1@att.net )
