D
DDSLT5
So, I tore the whole car apart yesterday, to install the HIDs, and to lift the airbag sensors, and clean and grease (dielectrically) and remount. I also cleans all the grounds, and greased them too.
Once done, I reset the codes - and all was well for about 10 minutes - the then light blazed again.
So today, I checked the codes and 16 (for the driver's side sensor) was back again. So I disassembled this side again, and this time placed stars beneath each mount to ensure an good ground. Tore it down, and built it up in under an hour - practice improves your times!!!
Cleared the codes again, and again, after 10 minutes, code 16 returns. So now what? Do I buy a new sensor for the driver's side?
Any help is appreciated.
Dwight
Dwight
