kcrowl
the dash has a light that says infl rest that is lit up can someone tell me what that is and how to fix thank you
You need to be more specific about when the info rest light comes on.
Does it come on immediately?
When you first turn the ignition On, the light should blink around 7 to 9 times then go out.
When cranking the engine the light should stay on.
There are two types of codes. With History codes you need a scan tool like a Tech 1 to read them.
Current codes you can read by doing the following.
Take a piece of wire or paper clip and short pin A to pin K.
Turn the ignition On.
The info rest light should blink 12 indicating it's in diagnostic mode.
12 would look like this. Blink short pause Blink Blink.
If there are no codes 12 will continue to blink.
If there are History codes after 12 Blinks there is a longer pause and 13 will blink.
13 would be Blink short pause Blink, Blink, Blink.
If there are Current codes they will Blink after the 12 or 13.
Example code 21 would be Blink, Blink short pause Blink. Longer pause and next code if there are any more.
After all the Current codes are displayed 12 will be displayed and the cycle will repeat.
Possible DERM codes.
21 22 23 24 25 26 31 32 33 34 35 41 42 51 61 and 71.
To actually clear any codes you need a Tech 1 or scan tool that can clear DERM codes.
