M
Mciamp99
I am placing a 1996 Grand Sport Motor into a 1975 vette. I am trying to make the motor run before I place the body back on the frame. My problem is that the fuel injectors will not fire with the fuel running through the rails. If I put fuel in through the throttle body the injectors pulsate until the fuel runsout. They will not allow any fuel to pass through them to the manifold. The motor has sat without fuel for 3 years. Is it possible that the fuel injectors (all 8) froze closed in that time?
Can someone offer some advice on checking these things?Any help would be appreciated. By the way, fuel pressure is almost 50psi.
