ecoman
i checked resistance on my inlectors warm have following readings 4 read between 16.8 and 17.0 and 4 read 4.0 to 7.0 what is the spec? will this cause a miss at idle and under slight load? thank you for any help
If I turn up anything more, I'll be sure to post it here.FUEL INJECTORS
There are a number of Fuel Injectors on the market today. The following injectors have been furnished on GM OEM systems: Lucas Bosch, Rochestor and Multec. The prices vary considerably and performance differences are hard to detect. Basically they are sized for application. The 5.0L injector is sized to deliver approximately 4.05 milligrams of fuel with a 2.5 millisecond pulse or 18.13 lbs per hr at approximately 36 PSI. The 5.7L injector is sized to deliver approximately 4.83 milligrams of fuel with a 2.5 millisecond pulse or 23.92 lbs per hr at approximately 43.5 PSI. This information is typical for all manufacturers and flowrates will vary slightly even between identicle injectors. A wide variety of flow rates are available to include 19lb/hr, 24lb/hr,30lb/hr, 36 lb/hr. These are all 16.2 Ohms and will work well with all GM TPI's Rochestor injectors are presently furnished for the 90-92 GM 5.7L engine. It has an all metal nozzle and performs well. Bosch injectors an excellent choice at approx $37.00 to$50.00 each.
While there are significant differences between the TPI and LT1 induction systems and computers, the injectors are essentially the same. Sequential port injectors and batch fired injectors are sized in the same manner.
