D
drkjr
Hi all... I've been perusing this forum for a while, but this is my first time actually writing....i need help! Actually my mechanic does...bastard's had my 1991 coupe for almost 2 weeks, and can't seem to find the problem...trial and error method, and it's costing me more and more dough! Here's the problem...
My car normally starts fine, but once in a while, usually on cold mornings, it'll just turn over, but sound like it's getting no fuel, won't kick over. If i wait between 10 and 30 minutes, it'll start... no big deal...that's just the beginning... the BIGGER problem is, when i am driving along, could be doing 50 mph, could be doing 20 (could be doing 100 !)...the car will just die... stall...i am now coasting... Service Engine Soon light comes on, once in a while the SYS will flash, but those 2 warnings are just temporary, they go away when i restart the car, which 95% of the time i can do while coasting off to the side of the road. Once in a while i have to pull over, wait 5 or 15 minutes, and then head on my way.
I'd also had a problem with my interior lights popping on sporatically, while i am driving, but my mechanic changed the switch in driver's door, and that fixed that problem. We both thought that that was what was causing the other problem, that it was security related, but no such luck.
He's changed the ignition module, that didn't work. He checked the fuel pump and IAC valve, he said both were good, that the car was getting good pressure. He's at a loss, and I am ****ed, it's my only car! He says that something is causing the injectors to shut down. Does anybody have any suggestions i can give him? Any help would be greatly appreciated! Thanks!
