gmboileau
Hi Tom
It's my understanding that the manufacturer of the Ford injectors indicates that you don't need the locking rings but it stikes me some sort of positive lock should be there as in the original. This is part of the problem with after market parts particuarly when the part is "designed" to fit many vehicles.
I thought about getting my original injectors cleaned but I decided against that because the weak point in the stock injectors is electrical which is a non repairable item. In effect what you get is a clean injector without the weak point being fixed and thus ready to fail in the future..near future?? Given the amount of work required to change the injectors, the cost of cleaning and the electrical issue I decided that I needed to replace my injectors with something that had new electrical parts.
New original parts were very expensive so I went with the Accel 24lbs. and in spite of my previous remarks about after market parts these use the locking clips, fit nicely and have a flow rate that the computer is able to manage without changing the prom . I used a scanner to see the integrator and block learn values and they are just fine.
Good luck on your project...
Cheers
Gary
Cheers
Gary
