B
Bad65
I just started having problems this weekend were the inside door handle won't work to open the door. I have to reach out and use the outside door handle to get the door open. First I need some help with how to get the door panel off...I believe I have the tool that is used. Need some step by step help if anyone is willing to take the time to explain. If any of you have had this problem and can pin point what needs to be replaced/fixed that would be such a help!
Thanks!
Thanks!
