miskowitch
I tried to install a vortex air filter on my 2001 coupe. I got to the point of taking off the plastic cover over the radiator and couldn't figure out how to get the remaining two screws out. There are five screws on the bottom that attach this plastic piece to the front body. Two screws on the lower part that attach to each side. The new airfilter requires a hole in this plastic.
Now the problem. There are two remaining plastic screws on either side about 1/2 way between the top and the bottom. These plastic screws have flat sheet metal like washers over the threads. How do these screws come out? There is about 1 inch of clearance to get a tool in. It doesn't look like a socket will work. There isn't any room behind to get them out either. Once they are out, I'm not sure how to get them back in either.
Any suggestions?
Thanks,
Any suggestions?
Thanks,
