H
Highball
Hey guys I have a 96 lt4 and I want to upgrade my wheels. I keep reading dif suggestions but has anyone had problems with putting newer vette wheels on c4's
I have a 96 C4 with C5 2000 wheels they are excellent and look good the tires came with them a mixture FP275/40/R17 93V on the front and RP275/40/ZR18 94Y on the rear.
I have no rubbing issues it pulls a bit to the right for some reason when I put them on butt is normal with the original saw blades on ???
Might have an odd wheel...
I've seen sets of 9.5" rims with one that was 9" from some replacement where nobody thought to check. One might be from a different set...different offset? All tires mounted to turn the correct direction? I cannot count the times a tire shop mounted tires backwards...
paid 375 for the set on craigs list so shop arround I believe my wheels were made in Italy
The OP had a 96 your 84's suspension is different and requires a different offset wheel than later C4sI tried to put 05 wheels on my 84.Not happeningI read on here somewheres not to use spacers because of safety reasons:confused
There are 11" sawblades out there.No offense, but for me, I prefer the look of the 96 stock blades on the C4, I think the spokes look really good on newer C5's & C6's, but not on a C4.:ugh
With that being said, I also am looking for a different set of rims I can use on my LT4 so I can run 315's on the back, and can only find newer Corvette look "spoke" rims. :ugh
Now i am considering just having my stock rims "re-finished" and giving up trying to run315's, and just go 285's. Anyone know of an alternative to be able to run 315's ??
