jonstr
Flight Judging wasn't stressful enough, so I'm trying to get my '69 ready for a Performance Verification. :eek I have a minor electrical problem and am stumped.
When you rotate the headlamp knob, the gauge lights are supposed to dim. They don’t on mine. I assumed this was a pretty easy fix, and I ordered a new headlamp switch. I got an OEM switch, and it hooks up correctly and everything operates correctly EXCEPT that the gauge lights still will not dim. It seems a mighty big coincidence that the new switch I got has exactly the same problem as my old (apparently original, by the look of it) switch.
Can anyone help me or point me in a direction with the following questions?
1) Is there another component that has anything to do with the gauge dimming function?
2) Is there a way to test the rheostat function on the switch itself?
On that last question, I’ve fumbled around with the wiring diagrams, the switch, and an ohm meter. I’ve located the wire (16 gauge dark green) that controls the on/off function of the instrument lights, but I cannot get it to read variable resistance with either the old or new switch. This would seem to point to a defective switch, except that I can’t get this test to work on the light switch from my ’63 either. That switch does dim the lights on my ’63, so I know it works correctly.
Thanks in advance for any suggestions.
