I have a nasty oil leak which looks like its coming from the back of the intake manifold. After driving about a total of 30 miles or so, I'm down a quart.
With the Chilton and Haynes manuals in hand, removal of the intake seems like a piece of cake (I think). It's the distributor removal that worries me...I have a stock distributor for my '72 LT-1. I have never done anything like this before, I hear you could mess things up pretty bad if this isn't done right.
Step 1 in Chilton:
1. Rotate the engine until the timing mark on the crankshaft balancer is aligned with the top dead center mark on the timing tab scale.
Can somebody please translate? Maybe provide some step by steps of how to do that? How do I rotate the engine?
2. Remove ignition shielding (I get that)
3. Release the distributor cap hold-down screws (push down and turn counterclockwise). Raise the distributor cap off the distributor and check the firing tip of the rotor is pointed at the #1 terminal of the distributor cap. If it is not; turn the engine one full revolution and again align the timing marks as previously stated. Recheck the rotor position.
What is the firing tip? Again, how to tun the engine? Align the timing marks?
What else should I watch out for during this project? And since I have to drain the coolant, I might as well do the heater core (since my dash is apart already) and change the hoses. I'll also probably change the carb gasket too (another thread, another problem) at the same time...
Step 1 in Chilton:
